조달청님 알려주세요..
작성자 츄리 작성일08-05-15 21:29 조회2,358회 댓글2건
일전에 전화드린 츄리입니다.
아무리 봐도 몰라서 문의드립니다.
제차는 (얼라이먼트 심)을 구입하여야한다고 하셨는데요..
저번에 나이스샵에서 구한수치는 1.9도와 1.4도입니다.
두개의수치를구입하여야하는데.
SPICER Part # 6221002   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4);
Plus Or Minus 1/4 Degree Camber; 4-3/4" Outside Diameter
이빨간색부분이 각도를 나타내는것같은데.
이게 몇도인지를모르겠습니다.
총 열거되어 있는것을 나열해보면.
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/4 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221003   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 3/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221004   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/2 Degree Camber ; 4-3/4" Outside Diameter
SPICER Part # 6221005   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 5/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221006   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 3/4 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221007   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 7/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221008   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221009   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221010   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/4 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221011   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-3/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221012   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/2 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221000   {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/8 Degree To 1-1/2 Degree Camber; 6 Bolt Holes; Full Range Adjustment
이렇게 나열되어 있습니다...
1.9도와 1.4도는 어떤걸 구입해야하는지요..
꼭좀알려주십시요 부탁드립니다....
꾸벅
mㅡㅡm;;
