조달청님 알려주세요..
페이지 정보작성자 츄리 작성일08-05-15 21:29 조회2,346회 댓글2건 |
일전에 전화드린 츄리입니다.
아무리 봐도 몰라서 문의드립니다.
제차는 (얼라이먼트 심)을 구입하여야한다고 하셨는데요..
저번에 나이스샵에서 구한수치는 1.9도와 1.4도입니다.
두개의수치를구입하여야하는데.
SPICER Part # 6221002 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/4 Degree Camber; 4-3/4" Outside Diameter
이빨간색부분이 각도를 나타내는것같은데.
이게 몇도인지를모르겠습니다.
총 열거되어 있는것을 나열해보면.
SPICER Part # 6221003 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 3/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221004 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/2 Degree Camber ; 4-3/4" Outside Diameter
SPICER Part # 6221005 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 5/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221006 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 3/4 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221007 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 7/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221008 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221009 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221010 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/4 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221011 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-3/8 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221012 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1-1/2 Degree Camber; 4-3/4" Outside Diameter
SPICER Part # 6221000 {Professional Grade}
Front Suspension; Four Wheel Drive (4X4); Plus Or Minus 1/8 Degree To 1-1/2 Degree Camber; 6 Bolt Holes; Full Range Adjustment
이렇게 나열되어 있습니다...
1.9도와 1.4도는 어떤걸 구입해야하는지요..
꼭좀알려주십시요 부탁드립니다....
꾸벅
mㅡㅡm;;
아무리 봐도 몰라서 문의드립니다.
두개의수치를구입하여야하는데.
이게 몇도인지를모르겠습니다.
총 열거되어 있는것을 나열해보면.
이렇게 나열되어 있습니다...
꼭좀알려주십시요 부탁드립니다....
꾸벅
mㅡㅡm;;
